Salta al contenuto principale
PlayStation VR Processor Unit Thermal Pad / Fan Replacement
Cosa ti serve
  1. PlayStation VR Processor Unit Thermal Pad / Fan Replacement, Processor Unit Thermal Pad: passo 1, immagine 1 di 2 PlayStation VR Processor Unit Thermal Pad / Fan Replacement, Processor Unit Thermal Pad: passo 1, immagine 2 di 2
    • Place the PlayStation VR processor unit with the I/O (back) side facing up.
    • Peel the sticker up with a fingernail or a pry tool.
    • Remove the single J0 screw.
    • Place the screw in a parts tray to keep it organized.
  2. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 2, immagine 1 di 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 2, immagine 2 di 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 2, immagine 3 di 3
    • Use an opening tool to separate the bottom cover from the top.
  3. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 3, immagine 1 di 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 3, immagine 2 di 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 3, immagine 3 di 3
    • Remove the eight J0 screws.
    • Place the screws in the parts tray
    • Use your tweezers to disconnect the fan connector from the motherboard
    • If the fan needs to be replaced, stop here and follow in reverse.
    • Fan details.
    • Brand: Nidec
    • Model and dimensions: U35x05m 52aa7-56j14
    • Power: 5v and .18a
  4. PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 4, immagine 1 di 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 4, immagine 2 di 3 PlayStation VR Processor Unit Thermal Pad / Fan Replacement: passo 4, immagine 3 di 3
    • Use a spudger or a fingernail to lift the pcb in the direction highlighted
    • Gently separate the metal plate from pcb
    • Replace the thermal paste if needed.
    • Use a fingernail or a pry tool to see if the thermal pad is still soft. that means it still conducts heat. if hard, remove and replace the thermal pad
Conclusione
Altre 3 persone hanno completato questa guida.
Kalib Ellery
Membro da: 10/17/16
492 Reputazione
2 Guide realizzate
3 Commenti
Hi, is thermal pads being dry could be the reason for this processing unit not turning on? It lits the light for quick millisecond and goes out as i connect the barrel jack. :( I couldn't find any fix yet
Chandu Samarasekara - Replica
Is it neccessary to replace the thermal pad with another pad , or may I use normal thermal paste?
DasNexus - Replica
It must be replaced with another new thermal pad of the same thickness, in this case a 2mm pad. If you use thermal paste, there will be a lot of space between the heatsink and the chip, which could cause failures and overheating.
Rixson Perez -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 61
Tutti i Tempi: 2,299
