Salta al contenuto principale
How to replace or tighten the inner screws of an FC fan
Visualizzazioni: 1020
Visualizza statistiche:
Ultime 24 ore:
4
Ultimi 7 giorni:
24
Ultimi 30 giorni:
106
Tutti i Tempi:
1.020
Commenti: 0
Nessuno ha lasciato commenti su questa guida. Sarai il primo?
Vai ai commenti della guida
Completato: 1
1 persona ha contrassegnato questa guida come "completata". Sarai il prossimo?
Preferiti: 0
Nessuno ha preferito (e si è iscritto) questa guida. Sarai il primo?
Tempo necessario: 5 - 10 minuti
Difficoltà: Facile
If your FC Desk Fan is making a rattling sound when you turn it on or if you notice the main body shaking while the fan blades are spinning, you will need to tighten the inner screws to keep the fan from potentially falling apart.
The inner screws hold the head and motor box of the fan securely to the main body. These screws can slowly come undone due to the natural vibration from the fan spinning.
Before beginning, be sure to turn the fan off completely and to disconnect it from any external power source.
Cosa ti serve
Strumenti
    1. How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: passo 1, immagine 1 di 3 How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: passo 1, immagine 2 di 3 How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: passo 1, immagine 3 di 3
      • Ensure the device is powered off completely and disconnected from any external power source.
      • Unlatch the four hinges located around the edge of the fan cage by gently pulling them away from the fan cage.
      Chiedi a FixBot
      Aggiungi Commento
    2. How to replace or tighten the inner screws of an FC fan: passo 2, immagine 1 di 2 How to replace or tighten the inner screws of an FC fan: passo 2, immagine 2 di 2
      • Locate, loosen and remove the screw that is found at the bottom of the cage using a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. How to replace or tighten the inner screws of an FC fan: passo 3, immagine 1 di 1
      • Remove the front half of the cage from the fan by wiggling gently it until it disconnects from the rest of the fan.
      Chiedi a FixBot
      Aggiungi Commento
    4. How to replace or tighten the inner screws of an FC fan: passo 4, immagine 1 di 3 How to replace or tighten the inner screws of an FC fan: passo 4, immagine 2 di 3 How to replace or tighten the inner screws of an FC fan: passo 4, immagine 3 di 3
      • Twist the now exposed central fan cap clockwise to remove it from the fan blades.
      Chiedi a FixBot
      Aggiungi Commento
    5. How to replace or tighten the inner screws of an FC fan: passo 5, immagine 1 di 2 How to replace or tighten the inner screws of an FC fan: passo 5, immagine 2 di 2
      • Twist the fan blades clockwise to remove them from the central axel.
      Chiedi a FixBot
      Aggiungi Commento
    6. How to replace or tighten the inner screws of an FC fan: passo 6, immagine 1 di 3 How to replace or tighten the inner screws of an FC fan: passo 6, immagine 2 di 3 How to replace or tighten the inner screws of an FC fan: passo 6, immagine 3 di 3
      • Remove or tighten the two inner screws as necessary, making sure the screws are tightened only until you are met with slight resistance when reassembling.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Autore
con
Zain Andani
Membro da: 09/12/23
133 Reputazione
Una guida realizzata
York University, Team 2-2, O'Regan Fall 2023 Membro di York University, Team 2-2, O'Regan Fall 2023
YORK-O'REGAN-F23S2G2
Membro di 1
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Ultime 24 ore: 4
Ultimi 7 giorni: 24
Ultimi 30 giorni: 106
Tutti i Tempi: 1,020
