Salta al contenuto principale
How to replace charging port in a Samsung Galaxy J3 (2016)
Cosa ti serve
    • When your Galaxy J3 smartphone has a problem with charging you need to apply this method to resolve it. If you need further help let me know in the comment
    Het glas was gebroken en dit vervangen Maar vanaf dan steeds de melding Batterij temperatuur te laag ? wat heb ik juist nodig en kan ik dat zelf ?
    Mvg ,
    Eddy
    eddy van den eynde - Replica
    Het glas was gebroken en laten vervangen door persoon van Repair Café Maar vanaf dan steeds de melding Batterij Temperatuur te laag ? Kan ik dat zelf herstellen en wat heb ik nodig ?
    Mvg ,
    Eddy
    The video is hard to see. I'm attempting to resolder new usb port.
    Besides solder gun, new usb and saulder, what else is needed?
    Tim Edris - Replica
    Thanks for videotaping this repair. Do you have a version that does not look like abstract are, though? I hate to complain but it is hard to make out exactly what's going on in this video.
    were you vacuuming the solder that had to be removed?
    What is the spec for the wire?
    thanks for any illumination you can provide on these topics.
    El Crashitan - Replica
Conclusione
Altre 9 persone hanno completato questa guida.
Alex Sander
Membro da: 02/28/17
38.219 Reputazione
202 Guide realizzate
2 Commenti
For beginners, this video explains the basic steps and equipment needed to replace any soldered usb port on any device.
And It is explained without annoying music.. LOL
https://www.youtube.com/watch?v=jGZKsuaJ...
Alan Sears - Replica
You Vedio are helping alot!please keep doing more of then!
MphoGift - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 66
Tutti i Tempi: 20,443
