Introduzione
If you notice that your bike tire is flat (and if re-inflating doesn't work or last long and the tire seems to be in a good state), you probably need to replace your bike tube. This guide will demonstrate the process and steps required to fix a worn out or punctured bike tube on a Trek 800 model bike.
Strumenti
Parti
Acknowledge that you have a flat tire.
A flat tire means deflated even without rider on the bike. If the tire is flat as soon as you get on it, it's not properly inflated. In general, the pression should be at the maximum (less wear, less risk of puncture, more speed, less efforts).
Disengage the rear brake before you remove the rear wheel.
Pinch the arms to compress the brake cable.
Pull the cable out of the lever and it will fully release.
If your break does not have a quick release (as shown in the picture) you may have to loosen the nut securing the brake cable to open the brakes.
Unscrew quick release lever found where the bike frame is attached to the rim of the tire.
Turn the lever then the quick release cap will unscrew "lefty-loosey".
Once it is loose enough you can pull the tire off, but do not pull it yet entirely off.
If your bike does not have a quick release for the wheel, you will need to unscrew the axle nut.
Pull out punctured tube from tire and replace with new tube.
Alternatively you might want to patch your tube's puncture.
If all of your steps were completed correctly you should be free to ride. Enjoy.
Un commento
Thanks for providing these instructions. But I think the most difficult step (getting the tire off the rim) should be explained in more detail.
