Salta al contenuto principale
How to replace Samsung Galaxy Note 5 motherboard
Cosa ti serve
Panoramica Video
  1. How to replace Samsung Galaxy Note 5 motherboard, Power off the Galaxy Note 5 and remove the S Pen.: passo 1, immagine 1 di 1
    • Power off the Galaxy Note 5 and remove the S Pen.
  2. How to replace Samsung Galaxy Note 5 motherboard, Remove the Galaxy Note 5 battery door.: passo 2, immagine 1 di 2 How to replace Samsung Galaxy Note 5 motherboard, Remove the Galaxy Note 5 battery door.: passo 2, immagine 2 di 2
    • Run the hair drier or heat gun around the edges of Note 5 on the back to soften the adhesive.
    • Gently pry up to release the battery cover. Be patient on this step as the battery cover is glued by strong adhesive.
  3. How to replace Samsung Galaxy Note 5 motherboard, Release the Galaxy Note 5 rear housing.: passo 3, immagine 1 di 3 How to replace Samsung Galaxy Note 5 motherboard, Release the Galaxy Note 5 rear housing.: passo 3, immagine 2 di 3 How to replace Samsung Galaxy Note 5 motherboard, Release the Galaxy Note 5 rear housing.: passo 3, immagine 3 di 3
    • Undo the 20 screws in the rear housing.
    • Remove the SIM card tray.
    • Pry up the wireless charging chip. Be careful not to damage the fragile flex ribbon. Insert the case opening tool into the gap between rear housing and LCD assembly to release the rear housing.
  4. How to replace Samsung Galaxy Note 5 motherboard, Release the Galaxy Note 5 motherboard.: passo 4, immagine 1 di 2 How to replace Samsung Galaxy Note 5 motherboard, Release the Galaxy Note 5 motherboard.: passo 4, immagine 2 di 2
    • Pry up the LCD and digitizer flex connectors, battery flex connector and proximity sensor flex connector.
    • Pry up the charging port flex connector, RF signal cable connectors and a connector underneath as shown in the picture to release the motherboard.
  5. How to replace Samsung Galaxy Note 5 motherboard, Remove the front and rear facing cameras.: passo 5, immagine 1 di 1
    • Remove the connectors of front and rear facing cameras if necessary.
Conclusione
Altre 21 persone hanno completato questa guida.
Mandy
Membro da: 12/05/14
9.518 Reputazione
9 Guide realizzate
9 Commenti
Where can I get a new motherboard as the sensor for my son pen is broken.
Logan kraft - Replica
in step 5 you are showing the motherboard of note 5 can you please remove the steel plates which is on the ic I mean the chips or ic I don't know what it's called I want to know which is charging ic/chip and which is PM(power management ) ic/chip please I want to know help me
maafia24 - Replica
*makes a tutorial thats impossible to do cause they dont provide links to buy the logicboard*
Miller Vititow (vitimilocity) - Replica
Isn't that frustrating? It is difficult to find repair parts because electronic devices aren't covered by current Right to Repair legislation. Here's more info about the issue: http://ifixit.org/right
Evan Noronha -
I have a Galaxy Note 5 N920G that has a water problem, everything just fine apart that it does not recognize the sim, so for calls and data is useless. I took it to Samsung , and they said that the motherboard or logic board does not work and need a replacement, but they want to charge me 300 usd that´s like a brand new note 5. Anyways browsing through eBay there are some boards but with different prefixes such as N920 A, V, T, N etc. I wonder if it will function with my cellphone? Will it be easy to replace the board?
Also im from Mexico if that helps.
Daniel Rodriguez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 14,259
