Salta al contenuto principale
How to repair loose threads
Cosa ti serve
  1. How to repair loose threads, Prepare the repair: passo 1, immagine 1 di 3 How to repair loose threads, Prepare the repair: passo 1, immagine 2 di 3 How to repair loose threads, Prepare the repair: passo 1, immagine 3 di 3
    • Identify the snag
    • Prepare your needle - for this guide we are using a specialized "snag repair needle" which has a textured end. These are available from most sewing shops.
  2. How to repair loose threads, Pull snag loop through: passo 2, immagine 1 di 3 How to repair loose threads, Pull snag loop through: passo 2, immagine 2 di 3 How to repair loose threads, Pull snag loop through: passo 2, immagine 3 di 3
    • Pass the needle through the bottom of the snag loop.
    • Wrap the thread around the sharp end of the needle.
    • Then, pass the needle through the fabric. The snag loop will also be pulled through by the textured part of the needle. Keep pulling it through, until both the needle and the snag loop are on the inside of the item.
  3. How to repair loose threads, Finished and ready!: passo 3, immagine 1 di 3 How to repair loose threads, Finished and ready!: passo 3, immagine 2 di 3 How to repair loose threads, Finished and ready!: passo 3, immagine 3 di 3
    • Pull tightly on the thread to secure it to the back of the fabric.
    • Then, reposition the fabric appearance on the front, by stretching it to balance the tension.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusione
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro da: 07/19/23
10.230 Reputazione
66 Guide realizzate
INTERSPORT Membro di INTERSPORT
Community
25 Membri
169 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 72
Tutti i Tempi: 920
