Salta al contenuto principale
How to repair hem/cuff binding
Cosa ti serve
  1. How to repair hem/cuff binding, Identify the defect: passo 1, immagine 1 di 3 How to repair hem/cuff binding, Identify the defect: passo 1, immagine 2 di 3 How to repair hem/cuff binding, Identify the defect: passo 1, immagine 3 di 3
    • Here, you can see the hole in the binding hem, where the stitching has broken.
    • If the binding is undamaged, you can easily repair this defective hem.
  2. How to repair hem/cuff binding, Tidy up the area: passo 2, immagine 1 di 3 How to repair hem/cuff binding, Tidy up the area: passo 2, immagine 2 di 3 How to repair hem/cuff binding, Tidy up the area: passo 2, immagine 3 di 3
    • Cut away any broken threads, to clean the binding area.
    • Then, position the binding properly again along the sleeve hem.
  3. How to repair hem/cuff binding, Position the hem on the sewing machine: passo 3, immagine 1 di 3 How to repair hem/cuff binding, Position the hem on the sewing machine: passo 3, immagine 2 di 3 How to repair hem/cuff binding, Position the hem on the sewing machine: passo 3, immagine 3 di 3
    • Remove the wide casing of the sewing machine, and slide the sleeve over the narrow part remaining.
    • Carefully line up the hem with the needle, and reposition the binding into the correct place.
  4. How to repair hem/cuff binding, Sew carefully: passo 4, immagine 1 di 3 How to repair hem/cuff binding, Sew carefully: passo 4, immagine 2 di 3 How to repair hem/cuff binding, Sew carefully: passo 4, immagine 3 di 3
    • Start sewing with a smooth tension to ensure the elasticity remains afterwards. Avoid bunching or over stretching the fabric.
    • Continue carefully until the end of the defective zone, and finish with a locking stitch.
    • Remove the item and check if the repair is holding, and whether the elasticity still stretches correctly.
  5. How to repair hem/cuff binding, Finished and ready!: passo 5, immagine 1 di 2 How to repair hem/cuff binding, Finished and ready!: passo 5, immagine 2 di 2
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusione
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro da: 07/19/23
10.230 Reputazione
66 Guide realizzate
INTERSPORT Membro di INTERSPORT
Community
25 Membri
169 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 76
Tutti i Tempi: 943
