Salta al contenuto principale
How to repair an iPhone that won't charge - Tristar Replacement
Cosa ti serve
  1. How to repair an iPhone that won't charge - Tristar Replacement, Check for a new charger: passo 1, immagine 1 di 1
    • Your cable could be bad, try a new one, possibly MFI certified ! (Made For iPhone) Or try a known-good one.
    • Try a new charging brick, or a known-good one that delivers at least 5V-1A
  2. How to repair an iPhone that won't charge - Tristar Replacement, Checking the charging port: passo 2, immagine 1 di 1
    • Check your charging port, it could be really dirty or obstructed
    • If it looks dirty, you can take the risk to insert a thin tool and try to pry out the dirt. I am not responsible for the harm you could do to your phone !
  3. How to repair an iPhone that won't charge - Tristar Replacement, Try known-good internals: passo 3, immagine 1 di 1
    • Try a known-good battery. Replace it if your phone charges again.
    • Try a known-good Lightning charging port. Replace it if your phone charges again.
    • I know, this is a picture of an iPhone 7, check the video for the 6S on the next step.
    • The whole french version of the process, video does help if you are an english-speaker !
  4. How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: passo 5, immagine 1 di 2 How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: passo 5, immagine 2 di 2
    • If you are still reading, bad news, you probably have a motheboard problem !
    • It's probably U4500, or Tristar that's causing it, it fails very frequently on iPhones. You'll have to replace it.
    • Video tutorial for Tristar replacement on iPhone 6S
Conclusione
Altre 12 persone hanno completato questa guida.
The Repair Academy Membro di The Repair Academy
Business
1 Membro
20 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 104
Tutti i Tempi: 10,878
