Salta al contenuto principale
How to repair a trouser/cuff hem (by shortening)
Cosa ti serve
  1. How to repair a trouser/cuff hem (by shortening), Defective hem: passo 1, immagine 1 di 3 How to repair a trouser/cuff hem (by shortening), Defective hem: passo 1, immagine 2 di 3 How to repair a trouser/cuff hem (by shortening), Defective hem: passo 1, immagine 3 di 3
    • Identify the defective area and assess how large the damage is.
  2. How to repair a trouser/cuff hem (by shortening), Prepare the hem: passo 2, immagine 1 di 3 How to repair a trouser/cuff hem (by shortening), Prepare the hem: passo 2, immagine 2 di 3 How to repair a trouser/cuff hem (by shortening), Prepare the hem: passo 2, immagine 3 di 3
    • Use a "seam ripper" tool to unstitch the original hem.
    • Unfold the hem.
    • Draw line above the defective part that you want to remove.
  3. How to repair a trouser/cuff hem (by shortening), Cut and invert the item: passo 3, immagine 1 di 3 How to repair a trouser/cuff hem (by shortening), Cut and invert the item: passo 3, immagine 2 di 3 How to repair a trouser/cuff hem (by shortening), Cut and invert the item: passo 3, immagine 3 di 3
    • Cut along the line and set the removed piece aside.
    • Turn the item inside-out.
  4. How to repair a trouser/cuff hem (by shortening), Mark out the new hem: passo 4, immagine 1 di 3 How to repair a trouser/cuff hem (by shortening), Mark out the new hem: passo 4, immagine 2 di 3 How to repair a trouser/cuff hem (by shortening), Mark out the new hem: passo 4, immagine 3 di 3
    • Draw a 1st line 2 cm from the edge - and a 2nd line with 2cm on top of it.
    • Fold the new hem twice on those lines.
  5. How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: passo 5, immagine 1 di 3 How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: passo 5, immagine 2 di 3 How to repair a trouser/cuff hem (by shortening), Iron and pin the hem: passo 5, immagine 3 di 3
    • Set up the iron on moderate heat without stream
    • Fixed the folded hem by ironing and then with pins.
  6. How to repair a trouser/cuff hem (by shortening), Sewing the new hem: passo 6, immagine 1 di 3 How to repair a trouser/cuff hem (by shortening), Sewing the new hem: passo 6, immagine 2 di 3 How to repair a trouser/cuff hem (by shortening), Sewing the new hem: passo 6, immagine 3 di 3
    • Use a sewing machine to fix the hem.
    • Stitch 2mm from the edge and add a locking stitch at both ends.
    • Stitch the 2nd line parallel with the first.
    • Cut the extra thread to make a clean finished seam. Turn the item right-way-round.
  7. How to repair a trouser/cuff hem (by shortening), Finished and ready!: passo 7, immagine 1 di 3 How to repair a trouser/cuff hem (by shortening), Finished and ready!: passo 7, immagine 2 di 3 How to repair a trouser/cuff hem (by shortening), Finished and ready!: passo 7, immagine 3 di 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Conclusione
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro da: 07/19/23
10.230 Reputazione
66 Guide realizzate
INTERSPORT Membro di INTERSPORT
Community
25 Membri
169 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 24
Tutti i Tempi: 389
