Salta al contenuto principale
How to repair LG G5 Power button ?
Cosa ti serve
Istruzioni Video
Conclusione
Altre 14 persone hanno completato questa guida.
Witrigs
Membro da: 11/24/15
69.454 Reputazione
378 Guide realizzate
12 Commenti
Does this cover the power button not functioning? The fingerprint but is vibrating but wont turn the phone on?
mrs_johnson79 - Replica
My power button had been working only intermittently and then almost not at all. The solution was amazingly simple. I wet a Qtip with alcohol and rolled it around the edges of the button, pushing in as much as I could. Each time I did that the button started working better and better. Now it works perfectly. I think between humidity, finger oil and dust, it just got dirty inside.
Simintov - Replica
This alcohol qtip comment helped. Button works again!
Sarah Young - Replica
I had the same problem with my LG G5.  I was very skeptical about the alcohol qtip idea but was all out of ideas and decided to give it a try.  After rubbing it with the qtip for about 5 seconds the button started to work again.  Unbelievable!  Thanks for the great tip.
Craig Meyer - Replica
Well %#*@. The alcohol and q-tip trick worked! I’m floored. I’ve been double-tapping since two months after I got the phone. I used cleaning alcohol, like that for wounds (70%), and pressed the button in with the saturated q-tip while scrubbing around and on the edge. As the above comments mentioned, repetition resulted in increased success: I used a total of one and a half q-tips, and applied alcohol about 3 or 4 times. No disassembly required.
Alexandra Ramsey - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 32,424
