Salta al contenuto principale
How to remove the Samsung LA40R81BD 40in LCD TV rear cover
Cosa ti serve
  1. How to remove the Samsung LA40R81BD 40in LCD TV rear cover, Rear Cover: passo 1, immagine 1 di 1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
Conclusione
Altre 11 persone hanno completato questa guida.
Richdave
Membro da: 04/09/10
32.051 Reputazione
30 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
3 Commenti
Got cover off but how to unplug the wires
cpeeledc - Replica
What size screws holds on the rear panel?
D Mack Miller - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 37
Tutti i Tempi: 24,114
