Introduzione
To perform maintenance on for instance the spark plugs, engine, or fuel rail, the air intake box needs to be removed.
Cosa ti serve
Unscrew the 10mm bolts.
Remove the push rivet with the flathead.
Unclip the cable from the bracket. Use the plyers to press the lock from beneath and pull the clip loose.
Pull back the clasps connecting the air intake box to the rest of the intake system.
Grab the box at the left side and pull up and towards the right to pull the top part of air intake box out.
Pull the intake pipe up and out.
To reassemble, follow these instructions in reverse order.
