Salta al contenuto principale
How to remove pilling
Cosa ti serve
  1. How to remove pilling, Material preparation: passo 1, immagine 1 di 3 How to remove pilling, Material preparation: passo 1, immagine 2 di 3 How to remove pilling, Material preparation: passo 1, immagine 3 di 3
    • Lay out the garment on a clean surface. Prepare the pilling shaver.
  2. How to remove pilling, Remove the pilling: passo 2, immagine 1 di 3 How to remove pilling, Remove the pilling: passo 2, immagine 2 di 3 How to remove pilling, Remove the pilling: passo 2, immagine 3 di 3
    • Smooth the garment to make sure it is flat before starting.
    • Make little circles with light pressure on the damaged fabric. The pilling will be cut away by the shaver.
  3. How to remove pilling, Finished and ready!: passo 3, immagine 1 di 3 How to remove pilling, Finished and ready!: passo 3, immagine 2 di 3 How to remove pilling, Finished and ready!: passo 3, immagine 3 di 3
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • Be sure to clean the lint from inside your shaver after use.
Conclusione
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro da: 07/19/23
10.230 Reputazione
66 Guide realizzate
INTERSPORT Membro di INTERSPORT
Community
25 Membri
169 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 22
Tutti i Tempi: 493
