Salta al contenuto principale
How to remove and clean the buttons
Cosa ti serve
  1. How to remove and clean the buttons, How to remove and clean the buttons: passo 1, immagine 1 di 1
    • First, we need to get inside the camera. Refer to the lens cleaning guide for steps on how to remove the front panel.
  2. How to remove and clean the buttons: passo 2, immagine 1 di 1
    • Once you have the front panel off, you are one step closer to accessing the keys. From here, you will need to remove the upper panel which will release the keys. Unscrew the screw and remove the small metal plate which holds the keys.
  3. How to remove and clean the buttons: passo 3, immagine 1 di 2 How to remove and clean the buttons: passo 3, immagine 2 di 2
    • Remove the keys and clean using solution and a soft cloth. If the keys are damaged, you will need to replace them. You can purchase parts for your camera on Olympus's website.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 699
