Salta al contenuto principale
How to remove FHX-720bt head unit in a 1999-2007 Chevrolet Silverado
Cosa ti serve
  1. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado, How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 1, immagine 1 di 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado, How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 1, immagine 2 di 2
    • Locate the hood latch in your vehicle found on the drivers side under the dashboard to the left of the parking brake pedal.
    • Pull the latch to release hood.
  2. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 2, immagine 1 di 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 2, immagine 2 di 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 2, immagine 3 di 3
    • Locate the release latch for the hood in between the grille and hood, directly above the "GMC" logo at the front of the car.
    • Lift up on the latch then raise the hood.
  3. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 3, immagine 1 di 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 3, immagine 2 di 2
    • Locate your battery in the front of the engine compartment near the headlight, on the driver's side.
    • Remove the black negative terminal with 5/16" socket or by using a 5/16" wrench.
    • BE CAREFUL. DO NOT CROSS POSITIVE AND NEGATIVE WIRES.
  4. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 4, immagine 1 di 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 4, immagine 2 di 2
    • Make sure the vehicle is on a flat surface, then use the parking brake.
    • Shift vehicle into 1st gear so the shifter will be out of the way for the next step.
  5. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 5, immagine 1 di 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 5, immagine 2 di 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 5, immagine 3 di 3
    • Firmly grasp the top of the dash trim and pull it towards you.
    • Once it is removed from its clips, pull up and the trim will come out the rest of the way.
    • Set the trim aside; you are ready for the next step.
  6. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 6, immagine 1 di 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 6, immagine 2 di 2
    • Remove the face plate from the head unit.
    • To do this, pull out on both the left and right sides to release the face plate from its clips.
    • After being released from the clips, set the face plate aside and continue to the next step.
  7. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 7, immagine 1 di 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 7, immagine 2 di 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 7, immagine 3 di 3
    • Remove three bolts using a 7mm socket wrench, two on the left and one on the right.
  8. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 8, immagine 1 di 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 8, immagine 2 di 3 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 8, immagine 3 di 3
    • Remove the head unit once the bolts have been taken out.
  9. How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 9, immagine 1 di 2 How to remove  FHX-720bt head unit in a 1999-2007 Chevrolet Silverado: passo 9, immagine 2 di 2
    • Place the head unit face down to allow the wires on the back to be visible and more easily accessible.
    • Listed below are the wires coming connected to the head unit. The colors correspond to the same color of the wire.
    • RCA inputs
    • Microphone input/wire
    • Power/audio/assorted control wire harness
    • Antenna input/wire
    • Harness disconnect
Conclusione
Altre 9 persone hanno completato questa guida.
Justin Reiner
Membro da: 09/29/15
317 Reputazione
1 Guida realizzata
Cal Poly, Team 15-1, Green Fall 2015 Membro di Cal Poly, Team 15-1, Green Fall 2015
CPSU-GREEN-F15S15G1
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,867
