Introduzione
If you have an old medicine cabinet and it is broken and are either deciding to throw it out and get a new one, or just cant afford one, then this is the guide for you.
This guide will help to recreate something old into something that is new and reusable,
It will save money and save you a trip to recycling.
Before using this guide make sure to have all the tools needed and that you have the time and patience to do this. Make sure to find the areas that need the most fixing so that those are the first steps you can work on and move on to the rest.
This project requires that you be very creative and just have fun!
Cosa ti serve
Remove four screws using a screw driver.
After wood filler has dried make sure to sand it.
Make the areas that were filled, nice and smooth, spray paint will not cover up bumps.
After all areas are nice and smooth, use paint color of choice.
Make sure the paint is for wood.
Spray paint and wait 3-4 hours to dry before painting other side.
Plastic plates are used to pour paint into.
Take a roller and dip it into paint.
Take stencil of your choice and place it onto the wood and use roller to fill the stencil space in with paint.
Use a a different plate for the pink paint and use a new roller.
Do the same thing with pink paint as was done with the blue.
Now take the doors after they have dried and decorate them both as well.
This time use white paint or color of your own choice.
Take stencil and fill in the space with the white paint.
Remember to have a place to pour the paint and use a new roller for the new paint color.
Do this for both doors.
