Salta al contenuto principale
How to realign HP Photosmart D110a scanner
Cosa ti serve
  1. How to realign HP Photosmart D110a scanner, Printer Hood Assembly: passo 1, immagine 1 di 1
    • First, begin by removing the printer's hood.
    • Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
    • Adjust the flap covering the scanner upward, as shown.
  2. How to realign HP Photosmart D110a scanner: passo 2, immagine 1 di 1
    • Remove the flap for the scanner. The flap is attached with two clips that can be dislodged by pulling lightly away from the printer.
  3. How to realign HP Photosmart D110a scanner: passo 3, immagine 1 di 1
    • Locate the three screws on top of the printer.
    • The orange circle shows a fourth screw located behind the power panel. Directions to remove this screw are in a later step.
  4. How to realign HP Photosmart D110a scanner: passo 4, immagine 1 di 3 How to realign HP Photosmart D110a scanner: passo 4, immagine 2 di 3 How to realign HP Photosmart D110a scanner: passo 4, immagine 3 di 3
    • Remove the three screws from the top of the printer with a T-9 screwdriver as shown.
  5. How to realign HP Photosmart D110a scanner: passo 5, immagine 1 di 2 How to realign HP Photosmart D110a scanner: passo 5, immagine 2 di 2
    • To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
    • Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
    • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the power button panel by pulling from right to left.
  6. How to realign HP Photosmart D110a scanner: passo 6, immagine 1 di 2 How to realign HP Photosmart D110a scanner: passo 6, immagine 2 di 2
    • Remove the exposed screw that was covered by the power button panel.
    • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
    • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
  7. How to realign HP Photosmart D110a scanner: passo 7, immagine 1 di 3 How to realign HP Photosmart D110a scanner: passo 7, immagine 2 di 3 How to realign HP Photosmart D110a scanner: passo 7, immagine 3 di 3
    • This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
    • Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
    • When all three cables are removed, lift the hood away from the printer and set it aside.
  8. How to realign HP Photosmart D110a scanner, Disassembling HP Photosmart D110a Printer Hood: passo 8, immagine 1 di 3 How to realign HP Photosmart D110a scanner, Disassembling HP Photosmart D110a Printer Hood: passo 8, immagine 2 di 3 How to realign HP Photosmart D110a scanner, Disassembling HP Photosmart D110a Printer Hood: passo 8, immagine 3 di 3
    • After being separated from the printer, the hood is ready to be disassembled.
    • Remove the only screw on the printer hood's underside, as shown. Use a T-9 screwdriver.
  9. How to realign HP Photosmart D110a scanner: passo 9, immagine 1 di 2 How to realign HP Photosmart D110a scanner: passo 9, immagine 2 di 2
    • With the screw removed, separate the two pieces of the hood by lifting it vertically.
    • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
    • Carefully pull down the white ribbon cable through the top piece of the hood.
  10. How to realign HP Photosmart D110a scanner: passo 10, immagine 1 di 2 How to realign HP Photosmart D110a scanner: passo 10, immagine 2 di 2
    • Carefully separate the two hood pieces connected by the black ribbon.
    • Set the piece of the hood down such that no stress is applied to the scanner as it is attached by ribbon cable.
    • The printer hood should now be in 2 pieces.
  11. How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: passo 11, immagine 1 di 3 How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: passo 11, immagine 2 di 3 How to realign HP Photosmart D110a scanner, How to realign HP Photosmart D110a scanner: passo 11, immagine 3 di 3
    • After having the hood removed and disassembled, locate the scanner.
    • Adjust the scanner wheel such that fits into the path.
    • If the black ribbon cable is twisted, untwist it so it appears as shown.
Conclusione
Altre 2 persone hanno completato questa guida.
Tim Wise
Membro da: 04/01/11
173 Reputazione
7 Guide realizzate
Cal Poly, Team 10-38, Forte Spring 2011 Membro di Cal Poly, Team 10-38, Forte Spring 2011
CPSU-FORTE-S11S10G38
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,470
