Salta al contenuto principale
How to re-caulk a bathroom sink
Cosa ti serve
  1. How to re-caulk a bathroom sink, Caulk seal: passo 1, immagine 1 di 1
    • Clean and dry around the rim of the sink with a paper towel.
    • Make sure the old caulk is completely dry before moving on.
  2. How to re-caulk a bathroom sink: passo 2, immagine 1 di 1
    • Remove the old caulk around the rim of the sink with a utility knife.
  3. How to re-caulk a bathroom sink: passo 3, immagine 1 di 1
    • Remove any old caulk residue around the rim of the sink with a wet paper towel.
    • Then dry the area completely.
    • Ensure the area is completely clean and dry before applying the new caulk.
  4. How to re-caulk a bathroom sink: passo 4, immagine 1 di 3 How to re-caulk a bathroom sink: passo 4, immagine 2 di 3 How to re-caulk a bathroom sink: passo 4, immagine 3 di 3
    • Apply painter's tape around the rim of the sink while leaving a small gap for caulk to be applied.
  5. How to re-caulk a bathroom sink: passo 5, immagine 1 di 2 How to re-caulk a bathroom sink: passo 5, immagine 2 di 2
    • Place the caulk tube into the gun.
    • Slowly press the trigger to release a thin line of caulk and move around the edge of the sink as you go.
  6. How to re-caulk a bathroom sink: passo 6, immagine 1 di 3 How to re-caulk a bathroom sink: passo 6, immagine 2 di 3 How to re-caulk a bathroom sink: passo 6, immagine 3 di 3
    • Smooth out the caulk against the edge of the rim and counter with your wet index finger.
    • Keep a rag nearby to wipe excess caulk from your finger periodically.
    • Press against the caulk firmly while sliding your index finger as you go around the rim of the sink.
  7. How to re-caulk a bathroom sink: passo 7, immagine 1 di 3 How to re-caulk a bathroom sink: passo 7, immagine 2 di 3 How to re-caulk a bathroom sink: passo 7, immagine 3 di 3
    • Pull the tape away from the counter immediately after applying the caulk.
    • Pulling away from the counter will help keep the caulk in a straight line.
  8. How to re-caulk a bathroom sink: passo 8, immagine 1 di 1
    • Wipe off any excess caulk from the edge of the rim with a wet paper towel.
  9. How to re-caulk a bathroom sink: passo 9, immagine 1 di 1
    • Let the new caulk dry for at least a day before using the sink.
Linea Traguardo
Thi Nguyen
Membro da: 04/29/20
201 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 200
Tutti i Tempi: 5,000
