Salta al contenuto principale
How to perform a Hard Reset on the Nintendo DS Lite
Cosa ti serve
  1. How to perform a Hard Reset on the Nintendo DS Lite, Battery: passo 1, immagine 1 di 1
    • Turn the DS to the back side.
  2. How to perform a Hard Reset on the Nintendo DS Lite: passo 2, immagine 1 di 2 How to perform a Hard Reset on the Nintendo DS Lite: passo 2, immagine 2 di 2
    • This is the PH00 Screw,
    • Unscrew it.
    • The screw remains captive to the battery cover, you do not need to worry about losing it.
  3. How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: passo 3, immagine 1 di 2 How to perform a Hard Reset on the Nintendo DS Lite, Removing the cover: passo 3, immagine 2 di 2
    • Remove the battery cover.
  4. How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: passo 4, immagine 1 di 3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: passo 4, immagine 2 di 3 How to perform a Hard Reset on the Nintendo DS Lite, Taking out the battery: passo 4, immagine 3 di 3
    • Wedge the edge on the side of the battery using a spudger.
  5. How to perform a Hard Reset on the Nintendo DS Lite, .: passo 5, immagine 1 di 1
    • Take out the battery and leave it for at least 15-30 seconds.
  6. How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: passo 6, immagine 1 di 3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: passo 6, immagine 2 di 3 How to perform a Hard Reset on the Nintendo DS Lite, Inserting the battery: passo 6, immagine 3 di 3
    • Reinsert the battery.
    • Make sure the battery matches the + and the - connectors.
  7. How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: passo 7, immagine 1 di 2 How to perform a Hard Reset on the Nintendo DS Lite, Screwing in the cover: passo 7, immagine 2 di 2
    • Put the cover back on and screw it in.
  8. How to perform a Hard Reset on the Nintendo DS Lite, Finish: passo 8, immagine 1 di 1
    • If everything done correctly, You should be at the setup screen, It would look like when you got the ds from the store.
    • You can hold A + B + X + Y + R while turning on the system and the ds will boot into a ds cartridge without doing setup, you can boot the Game Pak/GBA Cartridge if you hold A + B + X + Y + L Instead.
Conclusione
Altre 3 persone hanno completato questa guida.
Artem Ivat
Membro da: 02/05/20
2.709 Reputazione
12 Guide realizzate
Kid fixers Membro di Kid fixers
Community
158 Membri
296 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 102
Ultimi 30 Giorni: 376
Tutti i Tempi: 9,476
