Introduzione
Most repairs require the espresso machine to be opened. This is shown here. Please note that there are models with a decorative frame made of metal and others made of plastic (shown here) .
Cosa ti serve
First check which model you have in front of you: Is the decorative frame made of chromed metal (picture 1) or of metallized plastic? (picture 2). In the first case follow this guide, in the second case you are in the right place here.
Lay the machine on its side so the bottom is facing you. Start using a metal tool at the bottom edge to pry off the trim. Use only plastic tools on the other edges to avoid damaging the frame. The notches gradually release with a loud crack.
Lift off the frame.
Ich finde es einfacher mit einem Tafelmesser auf der inneren Hinterseite zu starten. Siehe hier: https://youtu.be/NK6h9DDoC-w?t=50
Lay the machine on its side. Now you can lift off the side panel. There is a small notch in the top right and it is probably still a bit stuck.
In principle, the side with the service flap could also be removed in a similar way, but this is not necessary for many repairs.
Picture 2 shows the Moltio with side panel open:
pump
flowmeter
PCB
heater
Altre 8 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
VauWeh ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
Super Bilderklärung mit den farbigen Hinweisen.
So und nicht anders ist es richtig erklärt.
