Salta al contenuto principale
How to open the Huawei Watch GT
Cosa ti serve
  1. How to open the Huawei Watch GT, How to open the Huawei Watch GT: passo 1, immagine 1 di 1
    • Before you begin, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to open the Huawei Watch GT: passo 2, immagine 1 di 1
    • Remove the four Torx T3 screws (3.65 mm length).
  3. How to open the Huawei Watch GT: passo 3, immagine 1 di 3 How to open the Huawei Watch GT: passo 3, immagine 2 di 3 How to open the Huawei Watch GT: passo 3, immagine 3 di 3
    • Insert an opening pick into the notch at the top edge of the back cover.
    • Do not insert the opening pick deeper than 1 cm (1/3rd of an inch) to avoid damage to other components.
    • Use the opening pick to pry up the back cover of the Huawei Watch GT.
    • Do not remove the back cover assembly all the way yet—it's still connected to the mainboard.
  4. How to open the Huawei Watch GT: passo 4, immagine 1 di 2 How to open the Huawei Watch GT: passo 4, immagine 2 di 2
    • Carefully fold the back cover assembly to the side of the two watch crowns.
Conclusione
To reassemble your Huawei Watch GT, follow these instructions in reverse order.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
Altre 2 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
123 Membri
23.769 Guide realizzate
2Commenti sulla guida
Do you know what size the internal screws are for the HUAWEI gt2 watch? I managed to drop one into a black hole.
keegs_2090 - Replica
Hi keegs_2090!
The internal screws are 2.9 mm-long #000 Phillips screws with a 1.8 mm-wide head.
Dominik Schnabelrauch -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 118
Tutti i Tempi: 4,934
