Salta al contenuto principale
How to open the Flipper Zero
Cosa ti serve
    • Go to Main Menu > Settings > Power.
    • Select Power OFF, and confirm by pressing the Right-button.
  1. How to open the Flipper Zero, Remove the microSD card: passo 2, immagine 1 di 1
    • Eject the microSD card by pressing it with your fingernail.
    • Use a PH1 screwdriver to unscrew the four long screws holding the back cover.
    • Be careful, the screws are quite easy to strip.
  2. How to open the Flipper Zero, Open the back cover: passo 4, immagine 1 di 3 How to open the Flipper Zero, Open the back cover: passo 4, immagine 2 di 3 How to open the Flipper Zero, Open the back cover: passo 4, immagine 3 di 3
    • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
    • Once the latches are released, you can remove the bottom cover.
Conclusione
Sebastian Dorr
Membro da: 08/19/18
8.250 Reputazione
44 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 134
Tutti i Tempi: 679
