Salta al contenuto principale
  1. Locate the two grey latches on each side of the hood near the headlights. Pull the latches away from the hood to release the latches.
    • Locate the two grey latches on each side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. Reach underneath the hood and push up on the lever located in the front center of the hood.  You can now open the hood. Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
    • Reach underneath the hood and push up on the lever located in the front center of the hood. You can now open the hood.
    • Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
Conclusione
Altre 2 persone hanno completato questa guida.
Ryan Smith
Membro da: 26/09/2012
281 Reputazione
1 Guida realizzata
Cal Poly, Team 7-51, Forte Fall 2012 Membro di Cal Poly, Team 7-51, Forte Fall 2012
CPSU-FORTE-F12S7G51
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 104
Tutti i Tempi: 21,850
