Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Philips TV 24PFS5242, usa il nostro manuale di assistenza.
  1. How to open back cover to get access to PCB, Product: passo 1, immagine 1 di 2 How to open back cover to get access to PCB, Product: passo 1, immagine 2 di 2
    • This is the Philips TV to be disassembled.
    • The stand is actually a loudspeaker and subwoofer system
    • There are no visible screws on the cover other than at the bottom of the stand which does not help to disassemble
  2. How to open back cover to get access to PCB, Back Cover view: passo 2, immagine 1 di 3 How to open back cover to get access to PCB, Back Cover view: passo 2, immagine 2 di 3 How to open back cover to get access to PCB, Back Cover view: passo 2, immagine 3 di 3
    • The (large) aluminum clip is attached to the back cover and the subwoofer preventing the back cover to come off
    • It needs some force to move, push the aluminum clip towards the subwoofer stand in order to release the two latches holding the clip to the back cover
  3. How to open back cover to get access to PCB, Back Cover removed: passo 3, immagine 1 di 1
    • Remvoved back cover with the two holes for the clip latches
    • The back cover itself is just as usual "clicked in" the frame
  4. How to open back cover to get access to PCB, PCB: passo 4, immagine 1 di 1
    • Back cover removed giving access to the power supply and main board
    • The subwoofer can also be detached from here
JKL Consulting Membro di JKL Consulting
Business
1 Membro
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 219
