Salta al contenuto principale
How to open and close a Metabo St EP 455
Cosa ti serve
  1. How to open and close a Metabo St EP 455, loosen the cover: passo 1, immagine 1 di 2 How to open and close a Metabo St EP 455, loosen the cover: passo 1, immagine 2 di 2
    • Make sure the jigsaw is unplugged.
    • Unscrew the bolt holding the guide plate to the jigsaw.
    • Unscrew the 10 screws holding the 2 frame halves together.
  2. How to open and close a Metabo St EP 455, separate the 2 halves: passo 2, immagine 1 di 2 How to open and close a Metabo St EP 455, separate the 2 halves: passo 2, immagine 2 di 2
    • Separate the 2 halves by slowly prying them apart, going around the edges evenly.
    • When separated, take care of some loose parts.
    • The nut holding the guide plate bolt.
    • Piece of plastic holding some cables.
    • Metal strip pushing the blade back.
  3. How to open and close a Metabo St EP 455, prepare to put the halves together: passo 3, immagine 1 di 2 How to open and close a Metabo St EP 455, prepare to put the halves together: passo 3, immagine 2 di 2
    • Regardless of how the halves are separated, to put them back together, it is practical to put the saw blade mechanism in the halve with the rest of the parts.
    • Then, make sure the right parts line up and are fitted correctly:
    • The holes for the blade holder. The axis is located on the other halve.
    • The blade driver.
    • The blade guide.
    • The metal strip.
  4. How to open and close a Metabo St EP 455, close it: passo 4, immagine 1 di 1
    • Now, add the empty halve on top of the halve containing the parts.
    • Screw everything back together.
Linea Traguardo
knipwim
Membro da: 09/01/18
8.517 Reputazione
30 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 30
Tutti i Tempi: 1,472
