Salta al contenuto principale
How to open an Aneng AN8008
Cosa ti serve
  1. How to open an Aneng AN8008, Place the multimeter on its front: passo 1, immagine 1 di 2 How to open an Aneng AN8008, Place the multimeter on its front: passo 1, immagine 2 di 2
    • Place the multimeter on its front.
    • Flip up the kickstand.
  2. How to open an Aneng AN8008, Unscrew the battery cover: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Phillips #1 Screwdriver
    $5.49
    • Use a PH1 screwdriver to unscrew the single screw holding the battery cover and kickstand.
  3. How to open an Aneng AN8008, Remove the battery cover: passo 3, immagine 1 di 2 How to open an Aneng AN8008, Remove the battery cover: passo 3, immagine 2 di 2
    • Remove the battery cover and kickstand.
    • Remove the batteries, if present.
  4. How to open an Aneng AN8008, Unscrew the back cover: passo 4, immagine 1 di 1
    $5.49
  5. How to open an Aneng AN8008, Separate the back cover: passo 5, immagine 1 di 1
    iFixit Opening Picks (Set of 6)
    • Insert a pick into the top gap between the backshell and front cover.
    • Partly leverage the front cover away from the backshell.
  6. How to open an Aneng AN8008, Remove the back cover: passo 6, immagine 1 di 2 How to open an Aneng AN8008, Remove the back cover: passo 6, immagine 2 di 2
    • Insert a pick into the bottom gap between the backshell and front cover.
    • Fully leverage the front cover out of the backshell.
Conclusione
Sebastian
Membro da: 08/19/18
31.160 Reputazione
71 Guide realizzate
German Translators Membro di German Translators
Community
42 Membri
1.550 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 20
Tutti i Tempi: 244
