Salta al contenuto principale
How to open a bObsweep Robotic Vacuum for Repair
Cosa ti serve
  1. How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: passo 1, immagine 1 di 3 How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: passo 1, immagine 2 di 3 How to open a bObsweep Robotic Vacuum for Repair, bObsweep's cover: passo 1, immagine 3 di 3
    • Flip Bob over and remove the 7 screws around which hold the cover together.
    • Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
    • Depending on your model, there may be only 6 screws installed on bObsweep.
  2. How to open a bObsweep Robotic Vacuum for Repair: passo 2, immagine 1 di 3 How to open a bObsweep Robotic Vacuum for Repair: passo 2, immagine 2 di 3 How to open a bObsweep Robotic Vacuum for Repair: passo 2, immagine 3 di 3
    • There are two screw holes inside the brush compartment: one in the centre, one on the left end. Remove both and keep aside for reassembly.
    • There are five more screws around bObsweep's edges. Two are installed at the top and bottom, and one on the right end of the main brush.
  3. How to open a bObsweep Robotic Vacuum for Repair: passo 3, immagine 1 di 2 How to open a bObsweep Robotic Vacuum for Repair: passo 3, immagine 2 di 2
    • Flip bOb back over so you can see the screen. Lift the cover up to reveal bObsweep’s main board.
    • Detach the power inlet from the cover. Grip it and slide it out.
  4. How to open a bObsweep Robotic Vacuum for Repair: passo 4, immagine 1 di 2 How to open a bObsweep Robotic Vacuum for Repair: passo 4, immagine 2 di 2
    • Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
    • 1. On the bottom left corner: a small connector with red, black and white wires.
    • 2. One thick white wire that attaches on the right side of the previous connector.
    • 3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
    • Place the cover aside and begin your repair.
Conclusione
To reassemble your bObsweep, follow these instructions in reverse order.
Tatiana
Membro da: 06/28/14
737 Reputazione
17 Guide realizzate
1Commento della guida
Change battery, and still does what it did before. Battery life is one bar only, and the moment u push start it shuts right off. Even after charging all day. Please help
Gerqui Vila - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 45
Tutti i Tempi: 3,029
