Salta al contenuto principale
How to modify Belkin Sync Dock for iPhone with protective case
Cosa ti serve
  1. How to modify Belkin Sync Dock for iPhone with protective case, How to modify Belkin Sync Dock for iPhone with protective case: passo 1, immagine 1 di 1
    • A thin rubber case on the iPhone makes the lightning connector unreachable.
    • Let's see if the position of the connector can be altered.
  2. How to modify Belkin Sync Dock for iPhone with protective case: passo 2, immagine 1 di 2 How to modify Belkin Sync Dock for iPhone with protective case: passo 2, immagine 2 di 2
    • Remove the sticker on the back side of the dock.
  3. How to modify Belkin Sync Dock for iPhone with protective case: passo 3, immagine 1 di 2 How to modify Belkin Sync Dock for iPhone with protective case: passo 3, immagine 2 di 2
    • Remove the four screws
    • Take down the black plate
  4. How to modify Belkin Sync Dock for iPhone with protective case: passo 4, immagine 1 di 3 How to modify Belkin Sync Dock for iPhone with protective case: passo 4, immagine 2 di 3 How to modify Belkin Sync Dock for iPhone with protective case: passo 4, immagine 3 di 3
    • Remove the cable from the case (it pops out with ease)
    • Using a cutter, carefully, cut out the plastic around the base of the connector (about half of mm or so)
    • Make sure you don't cut into the lightning connector!
  5. How to modify Belkin Sync Dock for iPhone with protective case: passo 5, immagine 1 di 1
    • Connect the cable to an usb port and check if your phone charges.
    • If it's not enough, take out more of the excess plastic
    • Enjoy!
Conclusione
Altre 4 persone hanno completato questa guida.
bmdbest
Membro da: 12/08/16
593 Reputazione
4 Guide realizzate
4Commenti sulla guida
thanks for instruction.
Clemence Lee Wai Hong - Replica Condividi
I got the adjustable one but the plastic got broken by itself and now it works only when it wants. Not sure if I can fix it and replace it with a standard cable.
sorinsbarnea - Replica Condividi
Great solution but for some other reason it still does not work because the some apple ios update has rendered this dock/cable unrecognizable. thinking of replacing the cable and connector with a genuine apple cable.
X Gempler - Replica Condividi
Update to what i just posted... It does still work with an iPhone SE 2020 with iOS 15.7, but does not work with an iPhone 11. with iOS 15.7.. Go figure.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,280
