Introduzione
The USB Rubber Ducky is a powerful tool for security researchers, but it lacks a physical button to trigger its functionality. HAK5 considered several options during development, and an elegant solution was found: layering stickers inside the case above the button, allowing you to squeeze the case to press the button.
In this guide, we'll show you how to mod the case of the USB Rubber Ducky to add a squeeze-to-press button.
Cosa ti serve
First remove the the USB-C cap
Jam a flat object, such as your fingernail or a small screwdriver, in between the metal sheath and the Ducky on both sides.
Remove the metal sheath by pulling it off the Ducky.
Attrezzo utilizzato in questo passaggio:iFixit Opening Picks (Set of 6)$4.99
Carefully separate the top and bottom plastics by inserting a plastic pick at the seam.
Apply two to four layers of the sticker on the inside of the case, directly opposite the button.
