Salta al contenuto principale
How to make Dyson AM07 (more) useable!
Cosa ti serve
  1. How to make Dyson AM07 (more) useable!, Overview and button names: passo 1, immagine 1 di 1
  2. How to make Dyson AM07 (more) useable!, Add some dots!: passo 2, immagine 1 di 2 How to make Dyson AM07 (more) useable!, Add some dots!: passo 2, immagine 2 di 2
    • Plug in your glue gun and let it heat up.
    • I made a big dot on the oscillation button, another one on the Standby ON/OFF button, and two more dots (big and small) on the Airflow control buttons. I don't use the Sleep Timer so I haven't added any dots to those two buttons.
    • If you don't get it right on the first try, don't worry. Just wait a couple of seconds for the glue to cool down and remove the dot. The glue comes off without leaving any residue or marks on the plastic.
  3. How to make Dyson AM07 (more) useable!, Bonus points: make shapes: passo 3, immagine 1 di 2 How to make Dyson AM07 (more) useable!, Bonus points: make shapes: passo 3, immagine 2 di 2
    • I used a carpet cutter (sharpest knife I had lying around) to cut the dot on the Standby ON/OFF button into an "I" shape for a little bit of different tactile feedback.
    • Some more ideas for customization: while the glue is still fluid, stick little parts of plastic, for example, in it to get different kind of buttons.
  4. How to make Dyson AM07 (more) useable!, The result: passo 4, immagine 1 di 3 How to make Dyson AM07 (more) useable!, The result: passo 4, immagine 2 di 3 How to make Dyson AM07 (more) useable!, The result: passo 4, immagine 3 di 3
    • They could look better but the buttons are a lot more useable now, in my opinion.
Conclusione
To undo these changes and restore your remote, just peel off the dots.
Altre 4 persone hanno completato questa guida.
Frank
Membro da: 06/08/15
85 Reputazione
1 Guida realizzata
4Commenti sulla guida
I would not recommend this. I would just order custom buttons and use some 3m tape to attach to the remote. Also, I don't have any problems finding the right buttons in the dark to control my fan.
kayshawncartel - Replica
Good for you. Then just ignore this guide.
Frank -
Bit a crap mod me thinks… not well thought out… its pretty obvious that if you do this the control will no longer sit nicely on top of the fan! Better off learning your left from your right ;-)
Abdullah Khan - Replica
Useful, but not sure about the appearance.
I’m interested in how to alter a Dyson Hot & Cold fan bought in the UK for use in the US…if anyone has recommendations?
James Bowkett - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 75
Tutti i Tempi: 15,133
