Salta al contenuto principale
How to flash Lenovo IdeaTab A1000L
Cosa ti serve
  1. How to flash Lenovo IdeaTab A1000L, Welcome: passo 1, immagine 1 di 2 How to flash Lenovo IdeaTab A1000L, Welcome: passo 1, immagine 2 di 2
    • Requirements:
    • A internet conection
    • A charged A1000
    • A usb data cable
    • And most importantly a windows pc
    • Warning: don't do this if your tablet is already working or you modified the boot loader ,you can brick your tablet .
  2. How to flash Lenovo IdeaTab A1000L, Finding Firmware.: passo 2, immagine 1 di 2 How to flash Lenovo IdeaTab A1000L, Finding Firmware.: passo 2, immagine 2 di 2
  3. How to flash Lenovo IdeaTab A1000L, Unpacking the firmware: passo 3, immagine 1 di 1
    • Unzip the firmware and the flashtool in any folder only with latin characters.
  4. How to flash Lenovo IdeaTab A1000L, Flashing the firmware: passo 4, immagine 1 di 1
    • YOU CAN BRICK YOUR TABLET ON THIS STEP! I am not responsible for any bricking of a tablet.
    • open Flash_tool.exe. and select File > Open Scatter-loading file ... and select the file MT6577_Android_scatter_emmc.txt from the firmware folder
    • Check the box DA DL All With Check Sum and Press the Firmware -> Upgrade button
    • If this <-- happens check the firmware and delete checksum.ini from the firmware and try again
    • Plug in your tablet turned off
    • First wait if you get a green circle after flashing you have a successfully flashed tablet.
Conclusione
Congratulations you have a working tablet
SilverDimond
Membro da: 09/07/19
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 44
Tutti i Tempi: 827
