Salta al contenuto principale
How to fix the power button on a Synology DS212J
Cosa ti serve
  1. How to fix the power button on a Synology DS212J, How to fix the power button on a Synology DS212J: passo 1, immagine 1 di 1
    • Power down the Synology.
    • Since the power button no longer works you can go to the web interface [https://IP_address:5001], log in and select shutdown from the menu in the top right.
  2. How to fix the power button on a Synology DS212J: passo 2, immagine 1 di 1
    • Remove two screws from the back.
    • Make sure to put these screws where you can find them, mine are long gone!
    • Slide the side of the enclosure forward.
  3. How to fix the power button on a Synology DS212J: passo 4, immagine 1 di 1
    • As you can see the plastic of the power button has broken of.
    • I considered replacing the button but fabricobbled an easier fix.
  4. How to fix the power button on a Synology DS212J: passo 5, immagine 1 di 1
    • Remove the gray front with 3 screws for easier access.
    • Cut a bit of thin plastic to the right dimensions. (About 3 x 1 mm)
    • Superglue the thin plastic on the cross of the power button.
    • Re-assemble and if all is well you have a working power button!
Conclusione
Rogier Gerritse
Membro da: 01/17/22
160 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,062
