Introduzione
Full video:
This process requires a rework station.
This is common problem with PSP E1000 caused by bad solder joints. This can be fixed with a bit of preheating.
Panoramica Video
  1. Let's start dismantling. Let's start dismantling. Let's start dismantling.
    • Let's start dismantling.
  2. Insert wisdom here. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  3. Disassembling the screen. Disassembling the screen. Disassembling the screen.
    • Disassembling the screen.
  4. Remove this screw. Remove this screw.
    • Remove this screw.
  5. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  6. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  7. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  8. Carefully disconnect the battery connector! Carefully disconnect the battery connector! Carefully disconnect the battery connector!
    • Carefully disconnect the battery connector!
  9. Remove the thermal tape. Remove the thermal tape. Remove the thermal tape.
    • Remove the thermal tape.
  10. You must resolder main processor with Rework Station (this is special equipment). You must resolder main processor with Rework Station (this is special equipment).
    • You must resolder main processor with Rework Station (this is special equipment).
  11. Cleaning and assembling. Cleaning and assembling. Cleaning and assembling.
    • Cleaning and assembling.
Conclusione
Altre 3 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
163.516 Reputazione
304 Guide realizzate
Master Techs Membro di Master Techs
Community
285 Membri
800 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 93
Tutti i Tempi: 8,351
