Salta al contenuto principale
How to fix stuck Joy-Con Triggers
Cosa ti serve
  1. How to fix stuck Joy-Con Triggers, Removing Cover Screws: passo 1, immagine 1 di 1
    • Using the Tri-Point Screwdriver, remove the 4 screws keeping the Joy-Con's shell together.
  2. How to fix stuck Joy-Con Triggers, Opening the Joy-Con: passo 2, immagine 1 di 1
    • Lift the shell to reveal the internals of the Joy-Con
    • If you are fixing the opposite-side Joy-Con, it will appear to be a mirror image
  3. How to fix stuck Joy-Con Triggers, Locate the Button: passo 3, immagine 1 di 1
    • Locate the ZR or ZL Button inside the Joy-Con Controller
  4. How to fix stuck Joy-Con Triggers, Positioning the Button: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to lift the ZL button, then put it back into it's correct position
    • Put the button in a position where clicking is possible
  5. How to fix stuck Joy-Con Triggers, Place the Shell back on the Joy-Con: passo 5, immagine 1 di 1
    • Using the Tri-Point screwdriver, put the 4 screws back into place.
Conclusione
Congratulations, you did it!
Altre 7 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 64
Ultimi 30 Giorni: 275
Tutti i Tempi: 10,803
