Salta al contenuto principale
How to fix sticky buttons for a TI-30X IIS
Cosa ti serve
  1. How to fix sticky buttons for a TI-30X IIS, How to fix sticky buttons for a TI-30X IIS: passo 1, immagine 1 di 1
    • Use the #0 Phillips screwdriver to remove the 4 screws at the back of the calculator
  2. How to fix sticky buttons for a TI-30X IIS: passo 2, immagine 1 di 2 How to fix sticky buttons for a TI-30X IIS: passo 2, immagine 2 di 2
    • Use a Flat Head Screwdriver or a thin strong object like a card to separate the front and the back of the case.
    • Separate it carefully to not break the 8 clips.
  3. How to fix sticky buttons for a TI-30X IIS: passo 3, immagine 1 di 1
    • Use a pointed tool to push the battery out of its terminal until it is out far enough to remove with your fingers.
  4. How to fix sticky buttons for a TI-30X IIS: passo 4, immagine 1 di 2 How to fix sticky buttons for a TI-30X IIS: passo 4, immagine 2 di 2
    • Using a knife, Razor, or other perscion cuting tool, remove the top of the 10 plastic rivets that connect the keyboard sensor to the front case.
    • Be careful when moving the calculator when the rivets are gone since they keep the calculator's keyboard sensor and keys together when the calculator back case is off. Keep keys down to prevent the loss of keys.
  5. How to fix sticky buttons for a TI-30X IIS: passo 5, immagine 1 di 2 How to fix sticky buttons for a TI-30X IIS: passo 5, immagine 2 di 2
    • Use a flat tool to unclip the two tabs that secure the circuit board.
  6. How to fix sticky buttons for a TI-30X IIS: passo 6, immagine 1 di 1
    • Remove the circuit board, keyboard sensor, and keyboard membrane from the front case.
    • The circuit board has 2 wires connecting to the solar panel, This cannot be removed without soldering/desoldering the connecting wires. Move all listed parts above to a location where there is little to no tension on the wired to prevent damage.
  7. How to fix sticky buttons for a TI-30X IIS: passo 7, immagine 1 di 2 How to fix sticky buttons for a TI-30X IIS: passo 7, immagine 2 di 2
    • Use rubbing alcohol to wipe down both parts using q-tips or any other cleaning cloth.
  8. How to fix sticky buttons for a TI-30X IIS: passo 8, immagine 1 di 2 How to fix sticky buttons for a TI-30X IIS: passo 8, immagine 2 di 2
    • Using q-tips, remove the keys and clean the keyhole and the keys to ensuring that they are residue-free. When done, return all the keys to their original position.
    • Keys are very light and small, have a container or a safe location to keep keys to prevent keys from getting lost.
Conclusione
Yong Ho Kim
Membro da: 01/31/23
193 Reputazione
1 Guida realizzata
Un commento
Fantastic guide. Is there any concern with cutting the plastic rivets?
dfen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 521
