Salta al contenuto principale
How to fix squeaking on the GEN 2 Wheelchair
Cosa ti serve
  1. How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: passo 1, immagine 1 di 3 How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: passo 1, immagine 2 di 3 How to fix squeaking on the GEN 2 Wheelchair, How to fix squeaking on the GEN 2 Wheelchair: passo 1, immagine 3 di 3
    • Locate the source of the squeaking.
    • Typically, this will be one of the rear wheels, castor wheels, or brakes.
    • Clean and remove any dirt or rust from the source of the squeaking.
    • You may need to partially disassemble the squeaking part in order to thoroughly clean it.
  2. How to fix squeaking on the GEN 2 Wheelchair: passo 2, immagine 1 di 1
    • Check for improper assembly.
    • Refer to the teardown to check that the wheelchair is properly assembled.
    • Check for proper lubrication. If not lubricated, lubricate thoroughly with bike grease.
  3. How to fix squeaking on the GEN 2 Wheelchair: passo 3, immagine 1 di 1
    • Check to see if the squeaking has stopped by rolling the wheelchair around.
    • If the squeaking continues, recheck the chair thoroughly to locate the problem. Once located, repeat the steps until squeaking has stopped.
Conclusione
Squeaking can be caused by overly tightened connections. If problem still occurs after going through steps, try to slightly loosen bolts (half a turn of the wrench) near the source of squeaking.
Cal Poly, Team 14-8, Maness Spring 2013 Membro di Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Membri
15 Guide realizzate
1Commento della guida
A quick spray of Extralube C60 Trigger Spray will keep the components rust free and spinning for much longer... worth a go www.team-zx1.com
sandraphleb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,621
