Salta al contenuto principale
How to fix mouse wheel clicks on G903
  1. How to fix mouse wheel clicks on G903, How to fix mouse wheel clicks on G903: passo 1, immagine 1 di 1
    • Remove the soles (the aluminosilicate glass feet or slides) to access the screws, then remove them.
    • Separate the upper and lower case parts by splitting them into two from where they are connected.
    • If you remove the factory soles, you can't put them back on, so you need to buy them in advance. (See Prequisite guide for removal and replacement of the feet (soles).)
    • Do not pull too hard when opening the case since the wires inside are still connected.
    • There are 7 screws in total, 1 near the USB connector and 6 under the soles.
  2. How to fix mouse wheel clicks on G903: passo 2, immagine 1 di 1
    • Remove the pin by pushing it with a thin stick or screwdriver
    • Lift the wheel to remove it.
  3. How to fix mouse wheel clicks on G903: passo 3, immagine 1 di 1
    • Peel off the Kapton tape on the metal dome switch and take out the metal plate inside
    • Remove all of the kapton tape
    • DON'T LOSE IT! Once it's gone, it's almost impossible to find it, (Be careful as it will fly away in the wind).
  4. How to fix mouse wheel clicks on G903: passo 4, immagine 1 di 1
    • Bend so that the center rises by about 0.2mm
    • Be sure to secure it firmly before proceeding.
    • Do not bend it too much.
  5. How to fix mouse wheel clicks on G903: passo 5, immagine 1 di 1
    • Put the metal plate back
    • Affix Kapton tape to fix (if not available, cellotape can be substituted.)
    • Shape Kapton tape (scotch tape) with a cutter, etc.
Conclusione
To reassemble your device, follow these steps in reverse order.
Altre 3 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
jp en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
1Commento della guida
Putting a tiny kink into the metal dome worked perfectly. And I already had a roll of Kapton tape on hand. I never would've realized the little dome was only held on by the tape if not for this guide. Just figured the tape was there to prevent shorting on top or something. That thought made little sense once I saw a bunch of these buttons available and designed without tape but a metal case instead.
Themicles - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 15
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 210
Tutti i Tempi: 4,628
