Introduzione
If you drop your huion pen and it starts drawing on its own while hovering, it could mean the inner was pushed in and the pen constantly on. This guide will help you adjust the inner as it supposed to be.
Cosa ti serve
Remove the buttons first. (use a flat screw driver or something similar) (pic 1)
Push the silver tab & black tab down and push upwards to remove the mainboard
twist the white cylinder to adjust the height offset of the nub
Use a soldering iron to remove the wire (remember which one goes where.) (pic 1)
Mark the white plastic and the black one (so you know when to stop when screw it back) (pic 2)
Unscrew the white part. Just one or two turns to bring it back to the original position. If you would like to see what's inside, remember which way the spring goes when unscrew the whole thing. It's revrsed in this pic (pic 3)
Put everything back together. Stop the white plastic at the mark. Put the tip on to see if the spring works (the tip moves freely; turn the white plastic back or forth to get a design pressure sensitivity).
Remember to pull the metal up or else the pen won't have power. (pic 2)
Altre 7 persone hanno completato questa guida.
17 Commenti
Man can I ask you something on google hangouts ? I couldn’t understand some points.
I don't have hangout. Just ask here, I'll try to answer asap
Why we need soldering iron?
To use in step 2
I suspect this happened to mine but i dont have a soldering iron
If the tip drops on the floor, the white part will be easily pushed in, which tighten the tip and makes it thinks that you're writing. You need to loosen the white part by any mean. I would recommend buying a soldering iron (online usually cheaper). If you need the pen asap, buy a basic soldering iron at Walmart or home depot (find the cheapest one available) will , you don't need anything else.
Any need to remove black plastic which is under the white one?
(sorry, I thought I answered this one already) In case you still want to know, you should not remove that black plastic.
Thank you so much, this saved me dollars from buying new pen. What bonus, I really had some fun :3
Hi i something to know
You did nothing just take things off and bring it back
Hey , do we really need to solder it? And does this method really work? I am asking this because the pen online is expensive than the whole tablet and the pen included
Have a look at this video
help,, the copper wire broke when i tried to pull it :’))
Hi! I have the same problem with the Huion PW100 pen but it looks like different from the pen of your guide. Can you help me? Please...
What so you mean black point!? I don't have it!!… I am using hs64 is that the problem?
luna times - Replica
The black point ( picture 2) is the round dot that looks like a button. It's just a lock, push it to open/remove the inside of the pen (pic 3). Try and find some way to open the inside of the pen if you don't see a button like that.
thlong123 -
