Salta al contenuto principale
Come riparare un iPhone 7 bloccato sul logo Apple.
    • In questa guida imparerai come risolvere il problema all'avvio di un iPhone 7 [bloccato sul logo Apple]. In caso di problemi, basta chiedere!
Conclusione
Per rimontare il dispositivo segui le istruzioni in ordine inverso.
Altre 15 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Alex Sander
Membro da: 02/28/17
38.219 Reputazione
202 Guide realizzate
19 Commenti
Was the circuit changed? or was it done reballing?
Fabio Junior - Replica
Thanks for your interest :) Chip replacement with reballing.
Alex Sander -
thank you so much
What is the name of this compononte?
Where do I meet for purchase?
You need to get it from the another motherboard.
Alex Sander -
What exactly did you do? Just heat up that goddamned blue thing?
Alex Gray - Replica
It is called the reflow, you need to restore the proper connection between the chip and the motherboard.
Alex Sander -
My iPhone 7 is rebooting on Apple logo. If I remove this IC it is turning on. If put it again, the same rebooting.
Alex - Replica
Hello, which IC are you removing in order to let your phone starting? Thank you.
Florian -
Hi, so was you heat the specific components or you have replaced it with another one components from another logic board.
Valerio Raso - Replica
No, recalling involves heating up the solder just to the point where it melts. Once the solder cools back down It makes a better connection than before, therefor it is called “recalling” and not replacement.
Robert Garner -
I have an iPhone 7. before 6 months I put on the update whereas putting on the charger and went for the work. when I return home my phone was off . then I tried to on the phone then the notification was connected to iTunes. then I connected to 3u tools and did iTunes flash that was failed because of error code 10 . can you please find the solution for this issue?
Ahamed Afridi - Replica
Is it okay if I replace the complete logic board with a new one? What else I need to replace to make it 100% functional.
montyatan - Replica
Hello,
my Iphone 7 storage was full, and when opening any app it close directly and any try to delete data to make some had failed so I tried to shutdown the phone, when I tried to power it up again it stuck on apple logo, so i connected the phone to itunes and tried to update it, in the middle of the process itunes gave me unknown error 14, and then the phone stuck on recovery mode.
any idea to fix the problem without losing any data? would this method fix the issue? and would some applications like dr. fone fix it without any data loss?
(battery health is 76%)
thank you in advance.
leo - Replica
the downloaded software is IOS 13
leo -
how to set a hot air gun iphone board??
ABUTHAHIR - Replica
what if my home button doesn’t work while my phone is stuck on apple logo?
Amarilis Garcia - Replica
hi..what is this IC name? it is in which ciruit?
martin newton - Replica
Thank you.. worked perfectly.
Seraphim - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 89
Tutti i Tempi: 13,635
