Salta al contenuto principale
How to fix a wobbly Sony Ericsson w600i swivel
Cosa ti serve
  1. How to fix a wobbly Sony Ericsson w600i swivel, Back housing: passo 1, immagine 1 di 1
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  2. How to fix a wobbly Sony Ericsson w600i swivel: passo 2, immagine 1 di 1
    • Swivel the phone open.
  3. How to fix a wobbly Sony Ericsson w600i swivel: passo 3, immagine 1 di 1
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  4. How to fix a wobbly Sony Ericsson w600i swivel: passo 4, immagine 1 di 1
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  5. How to fix a wobbly Sony Ericsson w600i swivel: passo 5, immagine 1 di 1
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  6. How to fix a wobbly Sony Ericsson w600i swivel: passo 6, immagine 1 di 2 How to fix a wobbly Sony Ericsson w600i swivel: passo 6, immagine 2 di 2
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  7. How to fix a wobbly Sony Ericsson w600i swivel: passo 7, immagine 1 di 3 How to fix a wobbly Sony Ericsson w600i swivel: passo 7, immagine 2 di 3 How to fix a wobbly Sony Ericsson w600i swivel: passo 7, immagine 3 di 3
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  8. How to fix a wobbly Sony Ericsson w600i swivel: passo 8, immagine 1 di 1
    • The back housing is now disassembled, and the swivel assembly is revealed.
  9. How to fix a wobbly Sony Ericsson w600i swivel, How to fix a wobbly Sony Ericsson w600i swivel: passo 9, immagine 1 di 1
    • Tighten the four small Phillips screws.
    • The swivel assembly should now be less wobbly and loose, improving the function of the phone.
    • The screws are Phillips, 2.4mm.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 612
