Salta al contenuto principale
How to fix a torn piece of fabric
Cosa ti serve
  1. How to fix a torn piece of fabric, Torn Fabrics: passo 1, immagine 1 di 1
    • The tools needed are in the following pictures. Make sure the fabric you are using matches the fabric being repaired if its clothing.
    Chiedi a FixBot
  2. How to fix a torn piece of fabric: passo 2, immagine 1 di 1
    • Press the thread through the hole of the needle. Getting the end of the needle wet will help it through easier. Once that is done make a firm knot to hold it in place.
    Chiedi a FixBot
  3. How to fix a torn piece of fabric: passo 3, immagine 1 di 1
    • Place the new fabric on top of the torn fabric and poke the needle through the end of the tear. Make sure to make a knot to hold the first incision through.
    Chiedi a FixBot
  4. How to fix a torn piece of fabric: passo 4, immagine 1 di 1
    • Began looping your thread through the new fabric on top of the torn fabric.
    Chiedi a FixBot
  5. How to fix a torn piece of fabric: passo 5, immagine 1 di 1
    • Take your time looping the thread through and make sure it is secured.
    Chiedi a FixBot
  6. How to fix a torn piece of fabric: passo 6, immagine 1 di 1
    • Once at the end of the fabric make a secured knot and cut any extra fabric left.
    Chiedi a FixBot
  7. How to fix a torn piece of fabric: passo 7, immagine 1 di 1
    • Look at your finished project to make sure it is clean.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 54
Tutti i Tempi: 1,213
