Salta al contenuto principale
How to fix a ripped back pocket of jeans
Cosa ti serve
  1. How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: passo 1, immagine 1 di 3 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: passo 1, immagine 2 di 3 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: passo 1, immagine 3 di 3
    • Pin down the ripped portion of the jeans back pocket.
    • Use as many pins as needed to ensure the pocket does not slip from the correct place while sewing.
  2. How to fix a ripped back pocket of jeans: passo 2, immagine 1 di 2 How to fix a ripped back pocket of jeans: passo 2, immagine 2 di 2
    • Thread the needle with the polyester thread.
    • Use about an arms length of thread to ensure that you have enough to sew with.
  3. How to fix a ripped back pocket of jeans: passo 3, immagine 1 di 1
    • Cut the ends of the thread.
  4. How to fix a ripped back pocket of jeans: passo 4, immagine 1 di 2 How to fix a ripped back pocket of jeans: passo 4, immagine 2 di 2
    • Tie a double knot at the end of the two threads.
  5. How to fix a ripped back pocket of jeans: passo 5, immagine 1 di 2 How to fix a ripped back pocket of jeans: passo 5, immagine 2 di 2
    • Start to sew from the bottom of the pocket up.
  6. How to fix a ripped back pocket of jeans: passo 6, immagine 1 di 2 How to fix a ripped back pocket of jeans: passo 6, immagine 2 di 2
    • Remove pins as the needle and thread approaches the pins.
  7. How to fix a ripped back pocket of jeans: passo 7, immagine 1 di 3 How to fix a ripped back pocket of jeans: passo 7, immagine 2 di 3 How to fix a ripped back pocket of jeans: passo 7, immagine 3 di 3
    • Loop the needle through the thread to tie a knot to end and secure the sewing.
  8. How to fix a ripped back pocket of jeans: passo 8, immagine 1 di 1
    • Cut the loose threads to clean up the sewing.
Conclusione
Ashley Dembroski
Membro da: 07/19/20
157 Reputazione
1 Guida realizzata
UW Tacoma, Team S1-G2, Cardinal Summer 2020 Membro di UW Tacoma, Team S1-G2, Cardinal Summer 2020
UWT-CARDINAL-SU20S1G2
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 59
Tutti i Tempi: 3,654
