Salta al contenuto principale
How to fix a printer that won't print
Cosa ti serve
    • Make sure you have all the necessary tools before you start tearing apart your printer. For this example, I am going to be using an HP ENVY 110 printer. However, it should work for other printers as well. The stuff you need is listed below. Things in bold are required.
    • A screwdriver.
    • A computer.
    • Printer ink.
    • This guide (obviously)
    • When a printer feeds paper for printing, the rollers that transport the paper can sometimes cause the paper to jam.
    • Open the ink access area using a screwdriver (or in my case, my own strength) and locate the carriage access panel (circled).
    • Remove the panel n
Conclusione
Your file should print! If it doesn't, try the above steps again, or contact someone who fixes printers.
Altre 2 persone hanno completato questa guida.
Lappy4861
Membro da: 03/11/24
183 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 42
Tutti i Tempi: 468
