How to fix a printer that won't print
Introduzione
Vai al passo 1Have you ever printed a document, only to find out it hasn't print? Well, here's a guide to getting that document, presentation, whatever it is, to print!
Cosa ti serve
Ricambi
Make sure you have all the necessary tools before you start tearing apart your printer. For this example, I am going to be using an HP ENVY 110 printer. However, it should work for other printers as well. The stuff you need is listed below. Things in bold are required.
A screwdriver.
A computer.
Printer ink.
This guide (obviously)
When a printer feeds paper for printing, the rollers that transport the paper can sometimes cause the paper to jam.
Open the ink access area using a screwdriver (or in my case, my own strength) and locate the carriage access panel (circled).
Remove the panel n
Your file should print! If it doesn't, try the above steps again, or contact someone who fixes printers.
Preparati per le riparazioni future
Acquista tutti
