Salta al contenuto principale
How to Fix a Leaking Garbage Disposal at Flange
Cosa ti serve
  1. How to Fix a Leaking Garbage Disposal at Flange, How to Fix a Leaking Garbage Disposal at Flange: passo 1, immagine 1 di 2 How to Fix a Leaking Garbage Disposal at Flange, How to Fix a Leaking Garbage Disposal at Flange: passo 1, immagine 2 di 2
    • Unplug the garbage disposal from the power source.
    • Be sure to place the wall plug in a dry location for the duration of the fix.
  2. How to Fix a Leaking Garbage Disposal at Flange: passo 2, immagine 1 di 2 How to Fix a Leaking Garbage Disposal at Flange: passo 2, immagine 2 di 2
    • Loosen and disconnect the dishwasher drain hose from the garbage disposal unit by loosening the clamp and removing the screws with a flathead screwdriver.
    • Pull the gray tube from the disposal.
  3. How to Fix a Leaking Garbage Disposal at Flange: passo 3, immagine 1 di 2 How to Fix a Leaking Garbage Disposal at Flange: passo 3, immagine 2 di 2
    • Remove the three screws from the flange at the top of the garbage disposal unit. These screws are at the top right above the black disposal box.
    • Disconnect the lock-nut at the flange.
    • Adequate lighting is imperative for this step.
  4. How to Fix a Leaking Garbage Disposal at Flange: passo 4, immagine 1 di 2 How to Fix a Leaking Garbage Disposal at Flange: passo 4, immagine 2 di 2
    • Use the screwdriver to turn the locking ring counter clock-wise, disengaging the drain hose and disposal.
    • You will be able to hear the locking ring come undone after pushing it forcefully to the left.
    • The disposal will drop down—be sure to catch the disposal and place on the bottom of the sink.
    • Move from underneath the sink to the top of the sink.
  5. How to Fix a Leaking Garbage Disposal at Flange: passo 5, immagine 1 di 2 How to Fix a Leaking Garbage Disposal at Flange: passo 5, immagine 2 di 2
    • To remove the flange, push from underneath the sink with one hand and pull it out through the top of the sink with your other hand.
    • Scrape off ALL excess putty from the flange and the sink.
  6. How to Fix a Leaking Garbage Disposal at Flange: passo 6, immagine 1 di 3 How to Fix a Leaking Garbage Disposal at Flange: passo 6, immagine 2 di 3 How to Fix a Leaking Garbage Disposal at Flange: passo 6, immagine 3 di 3
    • Remove a small ball of putty and roll into a golf ball shape.
    • Roll the putty flat into a snakelike shape, approximately 3/4 inch diameter.
    • Be sure that the putty is long enough to wrap completely around the flange.
  7. How to Fix a Leaking Garbage Disposal at Flange: passo 7, immagine 1 di 2 How to Fix a Leaking Garbage Disposal at Flange: passo 7, immagine 2 di 2
    • Wrap the putty around the flange and place the flange back into the sink.
    • Press down hard into the sink and remove any excess Plumber's Putty.
  8. How to Fix a Leaking Garbage Disposal at Flange: passo 8, immagine 1 di 1
    • Reassemble the flange and garbage disposal by reversing these steps.
    • Put a sink stopper in and fill up the sink approximately halfway.
    • Remove the stopper and check underneath the sink to make sure there are no leaks.
Conclusione
Amy Haren
Membro da: 01/19/18
175 Reputazione
1 Guida realizzata
Un commento
How do you stop the flange screws from backing out? Fixed it yesterday and screws were loose already this evening…help…
Mike T - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 103
Tutti i Tempi: 6,215
