Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This is a simple repair. Open the device and reconnect the battery. No parts required, no screws. (for iPhone or Android)
FLIR will not repair FLIR ONE 2G! "if the device is under warranty, we replace the unit directly as they are not being repaired. ... The one and only option left for you, is to have it repaired somewhere else as we do not support units that are out of warranty."
Parti
Nessuna parte specificata.
  1. Open the device with the opening tool in crack along top edge of back side. Continue carefully opening the device around all four edges.
    • Open the device with the opening tool in crack along top edge of back side.
    • Continue carefully opening the device around all four edges.
  2. The two halves will separate very easily and the battery connector will detach very easily.
    • The two halves will separate very easily and the battery connector will detach very easily.
  3. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. OPTIONAL
    • OPTIONAL
    • Lay two pieces of 30 gauge solid insulated wire (wire-wrap wire) onto connector. Press into the two slots to make connections.
    • CAUTION - any wire or probe larger than 30 gauge is likely to damage the connector.
    • Use a multimeter to check the battery voltage, it should be about 3.7 V.
  5. Carefully reconnect the battery. The two halves of the connector press together easily when properly aligned.
    • Carefully reconnect the battery. The two halves of the connector press together easily when properly aligned.
  6. Press the two halves of the case together. You might see the LED in the button light or start blinking!
    • Press the two halves of the case together. You might see the LED in the button light or start blinking!
  7. Charge the device. A blinking LED indicates charging, a steady LED indicates done.
    • Charge the device. A blinking LED indicates charging, a steady LED indicates done.
    • When charged, reconnect device to phone and try it!
    • You may get the message "Camera Files Not Received. Camera files could not be read, temperature accuracy and MSX alignment may be degraded." This is apparently a bug in some versions of the FLIR ONE App.
Linea Traguardo
Altre 13 persone hanno completato questa guida.
Frank Demarest
Membro da: 17/10/2017
571 Reputazione
1 Guida realizzata
Totally worked for mine! I almost gave up on it after seeing the YouTube video of the guy smashing his with a hammer. In addition I used a little bit of stablilant 22 contact enhancer product. Thanks Frank!
Todd - Replica
Cool you shared this info with other folks!
Worked for my Android device!
Dmitry G.L. - Replica
I can easily find a 185mAh battery but not a 350mAh. Not sure if anyone knows why its shrunk?
185 seems to work fine though.
Great guide. Sooooo easy.
georgedavies@hotmail.com - Replica
I have the Flir One Pro for Android with the same issue. I can’t figure out how to open it. I have an opening tool and there two plastic corners on the top connector face that come out. I can’t figure out how to get it open like you have.
chris - Replica
Nice guide. I accidentally broke the plastic connector on the mainboard (the pins are still soldered). Anybody know this connector type? Thx!
Peter D. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 22
Ultimi 7 Giorni: 141
Ultimi 30 Giorni: 659
Tutti i Tempi: 15,308
