Salta al contenuto principale
How to fix a clogged garbage disposal
Cosa ti serve
  1. How to fix a clogged garbage disposal, How to fix a clogged garbage disposal: passo 1, immagine 1 di 2 How to fix a clogged garbage disposal, How to fix a clogged garbage disposal: passo 1, immagine 2 di 2
    • Press the red reset button either on the front or on the bottom of your garbage disposal.
  2. How to fix a clogged garbage disposal: passo 2, immagine 1 di 2 How to fix a clogged garbage disposal: passo 2, immagine 2 di 2
    • Go to your breaker box and look for the breaker for your dishwasher. It may be attached to another appliance. Switch it off.
    • Do not continue without disconnecting the power.
  3. How to fix a clogged garbage disposal: passo 3, immagine 1 di 2 How to fix a clogged garbage disposal: passo 3, immagine 2 di 2
    • Unplug the garbage disposal from the outlet underneath the sink.
  4. How to fix a clogged garbage disposal: passo 4, immagine 1 di 2 How to fix a clogged garbage disposal: passo 4, immagine 2 di 2
    • Disconnect the garbage disposal pipe from the sewer pipe.
    • There may be excess water in this part of the pipe so place the bucket underneath.
  5. How to fix a clogged garbage disposal: passo 5, immagine 1 di 2 How to fix a clogged garbage disposal: passo 5, immagine 2 di 2
    • Using two screwdrivers, place them in the hooks on the top of the garbage disposal and push against them clockwise.
  6. How to fix a clogged garbage disposal: passo 6, immagine 1 di 2 How to fix a clogged garbage disposal: passo 6, immagine 2 di 2
    • Carefully bring down the garbage disposal from where it was connected to the sink.
  7. How to fix a clogged garbage disposal: passo 7, immagine 1 di 1
    • Remove the splashguard at the top of the garbage disposal that you normally see from the top of your sink.
  8. How to fix a clogged garbage disposal: passo 8, immagine 1 di 1
    • Using a screwdriver dislodge and remove any items clogging the disposal. This will give you an opportunity to manually move the blades around.
    • Never use your hand to move the blades.
Conclusione
Altre 4 persone hanno completato questa guida.
Katie Daffer
Membro da: 02/23/16
269 Reputazione
1 Guida realizzata
Texas Tech, Team 26-1, Rauch Spring 2016 Membro di Texas Tech, Team 26-1, Rauch Spring 2016
TTU-RAUCH-S16S26G1
3 Membri
1 Guida realizzata
2Commenti sulla guida
Would suggest also if you have a garbage disposal that has the hex wrench insert on the bottom you can use that to also spin the impeller to unjam the unit. Otherwise good to go
turbid - Replica
Yes most disposal units come with an Alan key so you can rotate the blades from the bottom of the unit. Rotate in each direction to un jam any thing check the red reset button. Then try it again most jams occur when not enough water is used to flush away the grinds.
Keith - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 70
Tutti i Tempi: 4,670
