Salta al contenuto principale
How to fix a Bathroom Door that Will Not Latch
Cosa ti serve
  1. How to fix a Bathroom Door that Will Not Latch, How to fix a Bathroom Door that Will Not Latch: passo 1, immagine 1 di 1
    • Check for any screws that may have become loose over time in your door hinges.
  2. How to fix a Bathroom Door that Will Not Latch: passo 2, immagine 1 di 1
    • If you found any loose screws on the door hinge, use your screwdriver to tighten them.
    • To make this easier, you can slightly lift your door while screwing the screws.
  3. How to fix a Bathroom Door that Will Not Latch: passo 3, immagine 1 di 1
    • Examine the faceplate, checking for any loose screws like you did with your door hinges.
  4. How to fix a Bathroom Door that Will Not Latch: passo 4, immagine 1 di 1
    • Use your screwdriver to tighten any loose screws found on the face plate.
  5. How to fix a Bathroom Door that Will Not Latch: passo 5, immagine 1 di 1
    • This is your strike plate. Take a look to see if it has shifted, and in what direction it shifted.
    • In the photo provided you can tell my plate has been shifted downwards.
  6. How to fix a Bathroom Door that Will Not Latch: passo 6, immagine 1 di 2 How to fix a Bathroom Door that Will Not Latch: passo 6, immagine 2 di 2
    • Use an electric power drill to remove the screws from your strike plate.
  7. How to fix a Bathroom Door that Will Not Latch: passo 7, immagine 1 di 2 How to fix a Bathroom Door that Will Not Latch: passo 7, immagine 2 di 2
    • Make a line on the wall where you will be moving your strike plate. Use something that you will be able to remove, such as a pencil.
  8. How to fix a Bathroom Door that Will Not Latch: passo 8, immagine 1 di 2 How to fix a Bathroom Door that Will Not Latch: passo 8, immagine 2 di 2
    • Using the wood chisel, chisel out the wood above the line to make space for the new placement of the strike plate.
    • An easy way to do this is to tap the end of the chisel with a hammer.
  9. How to fix a Bathroom Door that Will Not Latch: passo 9, immagine 1 di 2 How to fix a Bathroom Door that Will Not Latch: passo 9, immagine 2 di 2
    • Take as many toothpicks you will need to fill up the holes that were created for the previous screw holes, and dip them into the Elmer's glue.
  10. How to fix a Bathroom Door that Will Not Latch: passo 10, immagine 1 di 3 How to fix a Bathroom Door that Will Not Latch: passo 10, immagine 2 di 3 How to fix a Bathroom Door that Will Not Latch: passo 10, immagine 3 di 3
    • Place the toothpicks into the openings. By doing this, you are preventing your new screws from falling back into the old spot causing the door to be re-positioned again.
    • Let the toothpicks sit for about 10 minutes
  11. How to fix a Bathroom Door that Will Not Latch: passo 11, immagine 1 di 1
    • Place the strike plate in its new position.
  12. How to fix a Bathroom Door that Will Not Latch: passo 12, immagine 1 di 1
    • Using an electric drill, screw your strike plate into the wall.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 60
Tutti i Tempi: 3,939
