Salta al contenuto principale
How to fix Nikon D3000 shutter release button error
Cosa ti serve
  1. How to fix Nikon D3000 shutter release button error, How to fix Nikon D3000 shutter release button error: passo 1, immagine 1 di 2 How to fix Nikon D3000 shutter release button error, How to fix Nikon D3000 shutter release button error: passo 1, immagine 2 di 2
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right back of the camera bottom.
    • Remove three 3 mm x 5.5 mm from the bottom left of the camera bottom.
    • Lift the battery cover and remove two 3 mm x 5.5 mm screws from the bottom left of the camera.
    • Remove the screws from the bottom of the case to access the shutter gear.
  2. How to fix Nikon D3000 shutter release button error: passo 2, immagine 1 di 2 How to fix Nikon D3000 shutter release button error: passo 2, immagine 2 di 2
    • The second picture shows the bottom plate removed, but this is not necessary and requires intensive disassembling of the camera.
    • Blow out the red gear wheel to clean the wheel from any possible dust or debris.
    • Lubricate the red wheel to lessen the stiffness of the wheel's motion and rotate with the black plastic prying tool.
Conclusione
Altre 11 persone hanno completato questa guida.
Josh
Membro da: 08/26/15
328 Reputazione
1 Guida realizzata
USF Tampa, Team 14-7, Meier Fall 2015 Membro di USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 Membri
6 Guide realizzate
2Commenti sulla guida
I have a d3200 that “at will” will throw this message, so incredibly random. It will be fine then …. the message. Always at the worst moment. I have checked the mirror path and that doesn’t seem to be catching at all. I think I want to try this fix you outlined, but I have. D3200 not a 3000… is everything the same?
MARY M DUNNIGAN - Replica
Hello there.
I attempt many times to resolve issue on my camera. I tried lubricate red gear wheel, but problem persisting.
Does any other thing I need to do?
Salvador Diaz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 32
Tutti i Tempi: 12,349
