Introduzione
In this guide we will be showing you how to fix your Logitech M171 mouse laser not working
You’re done Thanks for completing the guide
Altre 3 persone hanno completato questa guida.
4Commenti sulla guida
Frying the darker plastic cover open without damaging it is near impossible. I have a problem with my mouse wheel and I don't know how to lubricate it or fix the sensor. Can someone help with that?
These are bad instructions, the top is released with 3 clips accessible under the battery cover, prising it off from above will break those clips. It can be hard to work out where the clips are and how to release them, but there are 3 one on each side and on under the battery. Aside from that the only other retention is a couple of hooks on the mouse buttons.
Agree that prizing the top off like this is going to damage it! Maybe my mouse, being blue on top, and black on bottom made this easier to spot, but it was very easy for me to see the three clips on the bottom. Hopefully anyone who wants to open theirs will see your comment and not use the opening tool like this.
es el modelo mas cercano que tengo del m170, porque necesito saber que pasa con la ruedita del ratón, por que bajo y sube, es difícil manejarlo
